Turbo Vado 2 4.0 or 5.0 or 6.0?
More conflicting info
This is the ride data graph from the Spec app showing segment where I was in 10/100 then changed to 0/100. From this it apears that the motor was indeed off. This directly conflicts with the Spec chart showing rider power needed to get max motor power. WTF?
it makes more sense that way.
you might need to try pedaling at 600+ watts just to make sure there isn’t some rounding going on. my recollection was similar to jeremy’s that at 5/10 ease settings the motor did not work very well.
Just finished a ride with 20 segments, about 1/2 mile long in 1-10 xx/xx and xx/100 tune settings. Now I get an error saying can't download file. Please try again later.
Also, turns out there is a 00/00 microtune setting as well as a 00/100. Setting the display to show rider power and motor power, there is 0 motor power regardless of rider power in both cases. Just what you would expect. BUT there is a clear motor whine with 00/100 but none at 00/00. clearly no whine with the regular "off" setting either. ????
My conclusion that the bike was really easy to PEDAL with the motor off, which I later retracted, I'm now asserting. ;)
