fooferdoggie
Ok doing that I just toss all the open runs. Since they need to cross.
Ya that works too. I want to see if the adjusters will me me using housing on both sides that will make it more solid. Look kind of coolMaybe. Couldn't you have them cross in front of the handlebars/headset before the cable stop and then run them parallel on the downtube with the front shifter housing on the outside?
I have the double or the heavy double on the tandem. This stupid thing is adjsutable but its at its shortest. so how the hell would it work with smaller bikes? I just wanted cheap keep spending money too easily, but I will fix it at work.You could use a hacksaw to shorten the kickstand. I have been using a Pletscher double leg kickstand and it works great. I have the Disc Trucker with 26" wheels.
That's what living rooms are for. Throw down a tarp and lie to your wife that it will all be cleaned up in a few hours.Well, it's hard ot bleed brakes in the rain. I just have the fenders left put the seat on and adjust everything.
my wife is blind she would just trip on something. but sicne the bike is much lighter, I can bring it into the den. Thanks for the idea. its imposible to get my ebikes up stairs.That's what living rooms are for. Throw down a tarp and lie to your wife that it will all be cleaned up in a few hours.
I had not thought about it because I guess it's been all e-bikes for so long they were too heavy to get up, then it was a recumebent and that was too big. Got the brakes done. The back was not too basd cutting the hose and putting the fittings on is pretty easy. the back was a little hassle till I realized I did not have the piston spacer between two of the 4 pistons. The banjo connection is actually pretty easy and lets you adjust the angle of the hose. but the front one would not work. the fill port was plugged and I had a spare caliper only a deore one, and used that one but I dont know if it was a bit wrong or what but I could not get any pressure at all. I had forgotten that was 3 years ago I took the bike in for the motor swap the front was not working and I was thinking it just needed cleaning.my wife is blind she would just trip on something. but sicne the bike is much lighter, I can bring it into the den. Thanks for the idea. its imposible to get my ebikes up stairs.
I am thinking of taking it to work for when I need to run arrends. But carry food most days I don’t buy once a week.I'd ride the pedal bike for the joy of it, but I'd pull the groceries on the ebike.
