getting a regular bike after my battery fails?
got the bottom bracket on. the left arm is a little thinner as it's a 105 arm so the screw does not quite sink in even with all the washers on the bottom bracket. think I need to put a washer behind the arm?
Are you planning to go tubeless with them?
(The price in Poland is around $30).
ya but 20.00 is even better. but not sure how much shipping is.
That bottom bracket is not right. It's probably designed for a 68mm square taper spindle. I would try moving the NDS spacer over to the other side, assuming that the DS BB cup has enough threads to engage it. If not, you may have to rethink your crank setup.
Shimano lists them as compatible on the chart that was posted. They are both hollowtech, but the arms are mixed, so it is going to take a little bit of fiddling. they dont make Shimano Deore power meter arms. There are plenty of threads on the bottom bracket to deal with. They feel good, and the arm is on well. is the the nut just a backup to keep the arm from sliding offor is it just to position the arm? dont I jsut need some of these till the preload screw engages?
this is pretty much it. got the fenders but they are hard to carry on a bike when not on a bike. I kind of wanted the wood fenders but they don't work quite as well and I did not want to spend 140.00 on fenders.
Now to 160mm rotors so sad the levers I have have this clicky thing going on both sets of Deore. I have had it happen after 8000 miles, so i figured it's easier to just change them one time. cable clamp black braze on cable adjusters another brake adaptor new brake pads the banjo connector for the brake hose. cable cutter spacers for the crankarm
This derailer is weird with the cable coming in the front but it's all I could find that is setup for my setup so either I use the guide on the bottom bracket like this or I use a clamp on the downtube and have it skip the bottom bracket. What do you think?
