Consumer Reports: Ebike Fires
A high charge rate increases the risk of a catastrophic battery failure, but the following is the kernel of the article :
Just modest indentation, bending or twisting of the batteries can cause nanoscopic fissures in the materials to open and lithium to intrude into the solid electrolyte, causing it to short circuit.
Even dust or other impurities introduced in manufacturing can generate enough stress to cause failure.
That last sentence above kind of has me a bit worried about my ebike batteries. I assume the cells they are constructed with are not from a top tier manufacturer.
E-bike fires made front page of NYT yesterday: https://www.nytimes.com/2023/03/06/realestate/e-bikes-fires-danger.html#commentsContainer (paywall). The extremely widespread use of e-bikes in NYC and its high population density make finding solutions difficult if not impossible, The anti e-bike folks are (rightfully) also seizing on the bad (i.e., illegal) riding habits, particularly, but not solely, of delivery folks. Reader comments are interesting and diverse. Tighter regulation/certification of batteries and plentiful safe charging locations might help, but implementation would be a dauntingly challenging...if not impossible.
New York has problems because of a flood of crappy ebikes and batteries. Comments like yours and even the general framing of the article obscure this or imply the opposite, as if the problem were inherent to electrifying bicycles, or really, any battery powered device.
Asher is correct. I was in NY City a few weeks ago. Most of the delivery ebikes, batteries, wiring, and ebike "store/charging stations" that saw looked really sketchy. Ebike delivery drivers, and the stores servicing them operate on slim margins, and there's a lot of DIY. Human nature being what it is, I presume that they cut corners when it comes to purchasing, repairing, and charging batteries. There's a big market in "used" batteries in that industry.
SQUATTERS are only in New York City, and not next door to US, OUR family right?
"Junkies, migrant squatters turn NYC block into a crime-ridden nightmare, starting blaze with stolen e-bikes that torched 2 nearby homes"
NYPOST
Moshe Kabasso with Luly Kabasso on the front porch of the home they were forced to leave after a blaze started at a squatter home next door.
Well, you want to go to the NY Post for the story.
Scooters with big batteries in a pile with ebikes. Idiots probably plugging in random chargers and jumpering wires when nothing works.
I’m reading this string today, 3 yrs after OP started it. Today I read locally of the 3rd home structure burning in my area since January. And yes, this one too officially blamed on e-bike battery charging. I see further legalities coming, harsher penalties coming, and tougher insurance requirements if you own/charge a battery.
I have never had a fire from any of the rechargeable things I have owned( dozens upon dozens) did notice the nicad batteries got very hot when worn out,just saying if you leave stuff plugged in for months stuff is bound to fail after awhile.
Unfortunately, you can't regulate or prosecute idiocy, which is the major cause of these fires.
And ignorance.... I ride with a fellow electrician and he has zero knowledge of battery safety and best practices. And quite frankly, he doesn't even seem interested which speaks to your comment. Same went for a fireman that I sold my original battery to.. but that was a few years ago.
Also the term ebike seems to be used now to cover the entire range of e-micromobilty out there
If this battery bank went up once before, hard to imagine that local fire officials didn't have a plan for next time. Wonder if that plan was the one actually executed in the 2nd fire?
Cars aside, lithium batteries large enough to become fire-bombs were pretty uncommon before ebikes exploded onto the scene. Firefighters had to figure out how best to fight these difficult fires in various settings and somehow put that knowledge into practice everywhere ASAP.
That's a tall order for humans. In every field I've been in (mainly science and medicine), that kind of widespread dissemination of best practices always takes far longer than it should.
Now that ebikes are everywhere, we need every firehouse in the land not only up to speed on lithium battery fires, but trained up and actually complying. From experience, I can tell you that old ways die hard — even when there's widespread agreement that the old way's got to go.
I guess its time to start using sodium based batteries or high end LFP the problem is the human factor. one problem I have is this,I never heard of a battery fire around here,where its common there seems to be negligence involved in a lot of cases.
Sodium is incoming, and once it proves its safety, local opposition to battery banks will fade, they are absolutely benign once we stop the catching fire and pumping out highly toxic gasses bit.
They also perform vastly better in the cold and heat.
