Magic (not real magic) chain lube for outstanding lasting performance and virtually no wear
I use Maxima chain guard in an aerosol can followed by Maxima chain lube (wax based) also in an aerosol. I never claimed my results were scientific. You've called "BS" on everything I've posted and then accuse me of being insulting? FWIW, I do indeed use the park tools CC2 chain checker which has a .25 hash mark. I also have a park tools 3.2 which is more of a go/no go checker and two other checkers as well. I did not realize one had to post scientific studies for chain lube durability before daring to post here. Again, you don't have to try it and you're convinced it doesn't work so I'm sure you won't. I'm hoping others might try it and be pleasantly surprised. I wasn't expecting the Spanish inquisition :)
I know it's popular today to not believe the science, but I guess I'm old-fashioned that way. But, your "information" just keeps getting worse and worse. You started out by posting this nonsense in multiple threads, and it's not insulting for me to point out the facts:
• First, you reference products that you said were "Maxima chain lube" and "Maxima chain wax." Turns out the "lube" product is actually called "Maxima Chain Guard."
• Secondly, it turns out those aren't bicycle products, so it would have been really hard for most readers here to have figured out which products you were actually using, since Maxima does make bicycle products as well - and they call the bicycle chain wax the same.
• Thirdly, Maxima itself DOES NOT RECOMMEND these motorcycle products for bicycles, saying: "We do not recommend you use these on bicycles for these products. These chain lubes are designed for the high speeds of motorcycle chains."
• Fourthly, the mechanism you claim for this combo's performance does not stand up to wax application science, where a clean dry chain is needed for proper wax adhesion. Furthermore, there isn't any advantage to mixing these two products. It's not like the lube prevents wear or reduces friction better than the wax - the wax is equal if not better in terms of friction reduction, and is better in terms of keeping the chain clean in dirty/wet environments. The reasons people use wet lubes today are ease of application and not having to wait for the wax to dry before riding, not because they're somehow lower friction, but need additional layers of something else to seal them in. Maxima describes the situation and conditions for choose which of their products to use, and never says to combine them.
• Fifthly, you claimed the "holy grail of chain maintenance" and "zero wear" after just 1500 miles, using at the time go/no-go chain checkers that couldn't detect wear under 0.25% (which itself is half-way to replacement for 12-speed chains). And, you later admitted you ride almost entirely in clean/dry conditions, the easiest for any of the lubes/waxes to perform in.
• Sixly, you don't say what your maintenance schedule is, nor how it's performed. How often do you clean your chain, how often do you reapply the lube and how often the wax top coat?
• The ZCF testing I've referenced does over 3700 miles of testing in varied environments including dust, sand, dirt and wet with no chain cleaning. It's a tough test, designed to weed out the superior products from the inferior ones. The tester points out that if you clean your chain every week and reapply lubricant, you'll probably gets 10,000 kms of use before wear is an issue, but that wastes time and money. Without knowing your cleaning/relubing schedule and procedure, it's impossible to weigh what you claim is so great.
I'm glad your happy with what you're doing with your chain. But when you claim things like "zero wear" and "holy grail" using products the manufacturer recommends against and in a combination that contradicts the science, you should expect serious push-back when you recommend that.
I did order 3 bottles of Rock N Roll Gold and ordered one bottle of T9. I will see over time what I eventually prefer.
The one bottle was Dumonde Tech Classic Original and not T9
I bought some dry lube when I first bought my e-bike, then bought the hot wax a month later.
I've never used the dry lube, but I like how the plants and animals give it their approval. 😁
You're NOT glad I'm happy with my chain maintenance routine. You have a bone to pick and you simply can't let it go.. Sad. A lot of things in science we take for granted today were discovered by accident. The microwave oven is one, penicillin is another. Without experimenting, this would be a very dull existence.... something you might be familiar with? :)
Yes, it is eating him up and is sad. I have never seen anything like it.
How ironic that the person ignoring the science of chain wax adhesion, ignoring the recommendations of the manufacturer of the products, and ignoring the results of the most scientific and independent tests we have available, compares his mixing of two commercial products to real science.
What's funny is that not even your supporters are trying your method. That pretty much says it all.
I'm quite sure you're an expert on "science" so there's that :) By now, I'm sure everyone here is well aware of your stance on this subject. Sweet and Low was also discovered quite by accident. By combining o-sulfobenzoic acid with phosphorus chloride and ammonia (tasting random chemicals is not generally considered a safe lab practice, "ignoring science" even) the man who was working on coal tar analysis noticed how sweet it was and tada,,,,, multi billion dollar product! So when my chain wax over chain lube technique really takes off and I become obscenely rich, I'll be sure to send you my regards.!!!! And if you don't find that even slightly humorous, all hope is lost
Somebody should reverse engineer this debate and start with a clean chain and hot wax treatment, followed by regular use of wet chain lube.
I'm predicting mixed and inverted results. 🤔
Maybe I'll do it?
I just cleaned and waxed my chain.
I've got the perfect wet lube for Winter,..
I think that the evidence will speak first itself.
Results similar to this, I suspect?? 😁
That makes sense 🤔
It's like searing in the juices when you fire up a steak. 😁
Just coat your chain in marine axle grease; it will last longer than the bike does since you don't pedal.
I'll still need to put the flames to it so it heats up and penetrates into the rollers.
So that part will be exciting. 🔥 💣 🙃
I think next I'm gonna try some dog s*it on my chain.
More than once in my life I've slid and nearly fell after stepping in it so it must be a good lubricant. And you don't have to worry about s*it sticking to your chain if it's already covered in it.
I mean the saying "it's slippery as s*it" must have some validity.
What a thought! Isn’t it great there are still people who think outside the box 😂
I used to use Maxima Chain Wax on my motorcycle chains. Motorcycle chains use o-ring seals on the links, bicycle chains do not. I tried it once on a new 10 speed chain. It made a mess. I changed back to RNRG.
That was the @stompandgo test method.
I've been using it for 8 years on bike chains.. No mess whatsoever compared to wet lube alone. I use the chain wax alone on my motorcycle chain (katana 1100) Zero fling off, zero mess. My test method has been called into question though so proceed with caution. The big advantage of maxima chain wax is that there is no mess from fling off
The ironic thing is that before use of o-rings (and now x-rings) in motorcycle chains (pre 1970s), owners would use a variant of the immersive wax treatment (eg Duckhams or Linklife) now recommended for bicycle chains. But, those products are no longer made because for the last half century motorcycle chain maintenance isn't about lubrication (chains are factory-lubed inside of the O or X ring seal), but about keeping the outside of the chain clean and rust-free and not drying out the o-ring.
Unfortunately, facts like these won't stop people from insisting that their misapplication of fundamentally different motorcycle products to bicycles is some kind of worthy scientific experiment, like the discovery of the microwave for cooking, and with vastly superior results than with products designed for bicycle use. Then again, what should we expect from those making claims of "zero wear" without proper instrumentation? I think the self-indulgent circle-jerk postings of potty humor on an e-bike forum is telling.
