I worked on a bike last week that I had designed four-years-ago as a climber for the big hills between my town and the coast. I put a 32-t chainring on it and an all steel 11-50 nine-speed cassette. Some motors are programable so you can create a power curve that applies more power at higher cadences. That prevents the crunch off the line that breaks stuff. 35 years ago I worked at a car dealership in LA. The detailers put Armor All on the clutch pedal of a Corvette so it looked nice and shiney. Backing up my foot went flying off, I smoked the tires and stalled the engine.It's definitely a learning curve especially for hunting season climbing these hills.
hub is around 220.00DT Swiss makes quality products. Good luck on getting an e-bike with one. E-bikes under $1800, 99.9% Chinese garbage sprockets freewheels/freehubs. Same garbage parts on unpowered bikes under $400.
I will definitely invest in a quality hub based on the information you all have provided. I really appreciate all the support.I put a race motor with dual 40DCOE's into my 1975 2002. I blew the transmission within 6 months, then replaced it. A few months later, I blew two junkyard rear ends. No crazy driving. Performance clutch. 140Nm into a cheap bicycle freehub is not going to last under high load.
I might have a dt-swiss hub I wount need I can sell. it may have to go to 40 spoke for our tandem.I will definitely invest in a quality hub based on the information you all have provided. I really appreciate all the support.
I get the sarcasm, but I'm not saying expensive, just quality. You don't need a DT Swiss or White Industries, although they are worth the money. Just get a hub that's designed for high load and not light weight. The Shimano TC-FH500 is designed for e-MTB's, a high torque application. There are others like this. You will need to match up the axle type and length, spoke count, and cassette type.I will definitely invest in a quality hub based on the information you all have provided. I really appreciate all the support.
I get the sarcasm, but I'm not saying expensive, just quality,.. Just get a hub that's designed for high load and not light weight.
Thank you for the video. I'll see what they have for my application.Onyx sprag clutch silent hubs.
Hello everyone. I wanted to share a video of the sprocket to ensure I purchase what I need. I appreciate everyone's help so far.the mentioned hub is one designed around a cassette and a freehub-body on the axle. You would need 2 items to remove the cassette (lockring), a lockring tool and a chainwhip (or a similar tool)
a "freewheel-type" all in one sprocket set with the freewheel integrated in it needs just one tool (TLFW30 is my favorite) and in most cases a strong bench vise and the look on your face as an angry bear.
Hard turn counterclockwise to get it free.... It usually takes a lot off force (freehun lockring is supposed to be tightend at 40Nm) because the chaindrive pulls the freewheel very tight on the BSA threaded part.
And yes I've managed to brake an actual benchvise while unscrewing a freewheel from an e-bike.... after lots of sweating/swearing
