Quad Lock for Turbo Como
mmp65
Canada
Is anyone using a quad lock case with their Turbo Como? Which kit did you purchase to mount on the handlebars? With the display that comes with the bike front and centre I am assuming you need to get one that connects right to the handlebars. Thanks in Adan e for any help
Welcome aboard! I don't have your answer, but I do recall discussions of the challenges involved in mounting things on the Como bars.
Use the forum search function with search strings like "Como handlebars" to find them. Maybe your problem's already been solved.
Thanks for the warm welcome and the suggestion
so turns out it doesn’t answer if anyone is using an actual quadlock mount and case. Hoping someone out there has.
I've used the Quadlock motorcycle handlebar mount on 4 bicycles, 2 tricycles and 4 motorcycles. Needless to say, they are very universal fit with interchangeable sleeves depending on your handlebar diameter. There is a standard mount and a "pro" version. I have both versions and for normal use, the standard one is great. Add the vibration dampener to keep your phone safe and you will need to get a Quadlock compatible case.
To give you an idea of durability, I have run these on mountain bikes and dirt bikes with crashes and not once had one fail or drop my phone. They are a little costly but so is your phone.
https://www.quadlockcase.com/
I have not used the Quadlock per se but I used something with very similar mounting to the Quadlock Stem Mount which uses bands to attach my wife's phone to her Como handlebars near the top and it seems to be very secure.
