Has anyone tried the new Rohloff E14 Trigger Shifter
Hawkshead
Has anyone tried the new Rohloff E14 Trigger Shifter yet
I have a Rohloff E14 Trigger Shifter, but I'm not sure if it is the 'new' one?
I have it, it is perfect and doesn't look like it was made on my bedroom 3D printer!
I have been using it now for 3 weeks and it is a really good upgrade. The only issue I have is that even though it works perfectly to change gear, I have a problem in not being able to upgrade the software on my Rohloff in order to be able to do recalibrations. I have contacted Rohloff and I am waiting for them to provide me with a solution. ( I specially purchased an android phone to download the version 1 app to do the software upgrade and followed all the instructions on their website, but it refuses to authenticate my hub, despite finding it !)
Did you hear back from Rohloff yet? I’m having the same issue As well. LBS doesn’t have an answer either.
This is the message they sent to me.... I have blanked out the code as I think it was specific to my bike.
Good luck !!
Dear Customer,
It is likely that an incorrect serial number is stored in the E-14 unit, which is preventing a connection from being established.
Based on the images and data you provided, we have generated the following temporary serial number for one-time use:
xxxxxxxxxxxxxxxx
Please enter the serial number without spaces – they are provided here for better readability only.
After the update, the serial number will be displayed either in the Bosch Diagnostic Tool (for dealers) or on the Kiox or Nyon 2 display.
Please note: If the displayed serial number does not match the serial number on your sticker, compare digits 7 to 12 of the serial number.
If these numbers do not match, the serial number must be reset at our facility. In this case, please send us the shifting unit for inspection.
Mit freundlichen Grüßen / Best Regards
Johannes Schindler
Good luck !!
Dear Customer,
xxxxxxxxxxxxxxxx
Johannes Schindler
Am I reading this thread correctly? To perform a software update, you first had to purchase an Android device. Next, somehow, presumably through no fault of your own, your E14 shifter unit was programmed with the incorrect serial number, i.e. the programmed serial number does not match the number on the external case sticker. So, your next steps are to remove the shifter, send to Germany, wait with no use of bike, then reinstall shifter? Note that shifter installation is not hard, but not quick, either. and post re-installation, you need to recalibrate, so presumably Rohloff will update prior to returning shifter? And who pays for the shipping?
Have they removed the annoying mandatory salutation/title form entries? It appears you are now just 'Customer,' lol.
Is your Rohloff service center in the UK or Germany? Imagine all of this if you are outside of Europe. I watched a Eurobike Rohloff presentation about the future auto-shifting product. I think, 'cool,' but then read threads like this and run away. It's been almost 3 months, and the shifter hasn't left the bike yet. Will your dealer put a loaner on the bike for you?
"pls send us the shifting unit for inspection" means "send photos?" I would have been filling out a customs report ...
Do you have to do that when shipping bike parts to a service facility? What a PITA!
Do you have to do that when shipping bike parts to a service facility? What a PITAo
Rohloff is in Germany. They have additional service centers in other counties to handle more common problems, so let's say you are swapping the shifter for another one -- that would take place within the US via USPS, UPS etc..
If you ship overseas, you must declare value. Entering $0 with description 'non-working' applies, but you still have to make the declaration. I suppose if your country has a service center, perhaps you could ship there, and let them forward to Germany, but that takes extra time. This is what I was curious about.
And I just looked it up. The UK has 3 service partners (the US has 2). Given proximity to continental Europe and a decent nr of service partners, this process is less of a pain in the UK, regardless. But the duration, 3 months, to address something that should be straightforward gives me pause.
I installed one on my Superdelight. I had to move the seat riser lever to get it to fit. It works fine, but IMO, they have it reversed. To me, it would be more intuitive to shift to a higher gear by pressing the lever forward. The way they have it set up, forward is a lower gear, and back is a higher gear.
I haven’t used one of these, but I think this might be the “standard,” Fleahound. My cabled, under-bar trigger gear selector uses a clicking pull over/around the bar with my index finger to snap to an indexed higher (smaller) gear, and an under-bar forward press with the thumb to push the derailleur into a lower (bigger) gear. Anyway, I’m not sure about the Rohloff as I didn’t see any pictures of it in action.
I do note that the literature says it can only be mounted on the right, although I was wondering if that was normal for European bikes.. I know I’ve heard that left and right brake levers are reversed (functionally) for some bikes. Now, that I find confusing! :D :D
