withiniswithout
The bearings in my front wheel are worn and apparently it's cheaper to replace the entire wheel.
The recommended replacement wheel, equivalent to the factory original, is a Rodi Webdisc ETRTO 622 X 19C. This is an aluminum wheel that is inexpensive, about $50 plus shipping.
My bike wheel has a 160mm Shimano disc brake rotor and a quick release lever, and it has Schwalbe 28 x 1.5 tires.
The ebike is quite heavy, a Gepida Alboin. I ride on a lot of fairly rough gravel.
Any recommended wheels to consider? I am in Italy.
Update: The shop had a 28", 36 spoke wheel, slightly wider than the oddball original 19C. The price was right so I had them put this on and it's fine. I also put clip-on spoke reflectors, about the size of a cigarette, bright white cylinders. I rather like the look.
