You must have been using industrial quality Flukes or Hewlett Packards from the old days,
No, just regular digital multimeters in the 80's from Radio Shack.
They had analog meters too that had to be adjusted.
We all knew about Fluke but Fluck That@!
Even our teacher couldn't afford one.
(Maybe he just knew better than to bring it to class.
The analog meters were only in electronics class from 1980-1982
We adjusted them every time we used them.
You touch the probes together then turn the dial until it reads Zero Ohms.
The Voltmeter and Ahmeter ranges didn't require a battery to operate properly, just a set of resistors and a couple shunts
Try a Harbor Freight meter, or a Craftsman. When their 9 volts go low, you get incorrect high DC readings,
My Canadian Tire digital Multimeter has been in the garage since I made my 36V battery pack in Sept 2022,..
The garage can be -20°C or +40°C in the summer.
I cut the plug off a cord and stuffed the probes of the Multimeter into the wires to plug it into the socket keep an eye on the battery voltage.
The battery in the Multimeter did actually die on me, but the symptoms were obvious and it didn't lose accuracy.
It just didn't work.
I remember opening it up and finding a battery that I had never seen before,..
Some smoke alarms and carbon monoxide detectors use them too.
All my other digital multimeters have a low battery indicator or the screen gets dim or they won't turn on when the battery dies.
