Checking in at 1K
Awesome! I love mine as well, and it has been trouble free as well.
In my riding area, I rarely need to go above 20 mph so my experience is somewhat limited. I definitely still feel-good motor support up to 25 mph. The speed limit above 25 is more about my crank rpm being higher than my desired target. This is with a 48 tooth chainring and 11 tooth cassette. I am in the process of installing a 50 tooth front chainring which should help a bit. I did not want to have to add any links to my chain or I would have gone to a 52 tooth chainring. I definitely do not need such a low gear even when climbing and I live in an area with substantial mountain passes.
I really am happy with the Bosch motor. The support is excellent and feels very natural. Battery life has also been very good.
Before my purchase, I had narrowed down my choice between a Trek Allant+ 7S and the Gazelle Ultimate T10+. Riding both, I did have a preference for the Gazelle. Riding position for me was more comfortable and I liked the adjustable handlebar stem. Also, the somewhat thinner tire size was also to my liking.
Hello! I've been reading this thread with interest, as I'm considering an Ultimate T10+. Unfortunately, I can't find any in stock near me to test ride. (Selling out, not popular, or discontinued?) I'm particularly interested in how adjustable the handlebar stem is, as I prefer a more upright posture. (Most of my riding is in the city and, well, I'm getting a little older and achy.) Could you give me an idea of how adjustable that stem is? How upright a posture can you get, if desired? For comparison, I'm also considering Trek Verve+ and Specialized Como and maybe even an Electra Vale. (I welcome comments on those options, too--or any other suggestions.) I found Gazelle's Arroyo to be really comfortable but strongly, strongly prefer a derailleur. Thank you for any thoughts!
I too like a more upright posture but not to the level of a cruiser type bike. I accomplished this by moving the stem to a more upright position. I will try to get a picture posted that shows this. Other modifications have been to use a more padded saddle and SQ Lab 710 grips.
As far as availability, I would talk with your local Gazelle dealer to see if the bike is something that is still available.
PS - I prefer a derailleur system as well for its simplicity.
Thank you!
Here are a couple photos of my handlebar stem. I have raised the stem angle which has helped to create a more upright riding position on my Ultimate T10+
I neglected my last two check-ins:
4K, August 26th, 2025
5K, January 15, 2026
Still zero complaints. On chain #2 and the rear brake might be getting a bit soft requiring a bleed. My company pays for milage if you commute some way other than driving yourself (bike, transit, carpool), and at 5K the bike has paid for itself in fuel cost savings + commute subsidies.
Happy Bike Month. 6000 miles each one lovelier than the last. Had one very mild crash going around a closed gate that knocked a few things askew. I realized that almost every screw on my stem was loose. How rigid do you think the torque ratings printed on the stem are? Can I just hand tighten everything and be satisfied or should I make a journey to the Bike shop to use/borrow/purchase a hex torque driver.
Congrats! Best to use a torque driver. Bike shop can probably recommend one, as some are more accurate than others.
You can tighten by hand, and it can come loose again. The torque specs are there for a reason.
You have many options for a torque driver/wrench, ranging in cost from $30 for a single torque setting wrench to hundreds for a digital torque wrench. I prefer analog wrenches. My small one is a Shimano PRO calibrated 1/4" drive wrench that I use with a 1/4"-hex adapter. For anything over 15Nm I use a CDI calibrated 3/8" drive wrench good to 75Nm along with 3/8" hex sockets.
