Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
I should have bought a Vado SL 5.0... Very happy with my heavily modded Vado SL 4.0 EQ (10-speed Shimano drivetrain) but now I am in the need to install a wide range cassette to get actual MTB gearing range. Even if possibilities exist to go with a huge 11-speed cassette, I think the drivetrain swap should be a radical one, so 12-speed drivetrain is in the plans.
I want you to help me with my decisions. Please do not talk SRAM... I simply do not want it.
The rear wheel of a Vado SL 4.0 might have the hub identical to the one used for SL 5.0 (it is named Specialized Alloy Hub 12x148 mm, thru-axle).
I think these components make sense:
Now: Has anyone tried to swap the Vado SL 4.0 drivetrain for the 12-speed one? Please advise. You might talk about the electronic drivetrain but then please provide a lot of detail.
@Allan47.7339: Ideas? You have always been good with giving excellent advices.
@e-levity: Can you help?
I would like to know about the Microspline Freehub body as much as possible. What is the one used on Vado SL 5.0?
The shifter: Does the Vado SL 5.0 shifter have a gear indicator? (I prefer not to have one). Is this shifter mounted on the brake lever assembly?
Thank you in advance for any help!
- Replace the HG+ freehub with a Microspline one. Here is where I am moving in the darkness. No experience at all!
Would that set do? https://r2-bike.com/DT-SWISS-Freehu...-12-speed-12x142-mm-12x148-mm-BOOST-Thru-Axle - Replace the cassette. 10-51T
Perhaps this one? https://www.rosebikes.pl/shimano-slx-cs-m7100-cassette-12-speed-2678997 - Replace the derailleur.
What do you think? https://bike.shimano.com/en-EU/product/component/slx-m7100/RD-M7100-SGS.html - Shifter. Vado SL 5.0 uses Shimano SLX RapidFire Plus shifter to be installed together with the Tektro brake lever assembly.
This one? https://bike.shimano.com/en-US/product/component/slx-m7100/SL-M7100-IR.html - Will the shifter come with the core of the cable in the set?
- A 12-speed Shimano chain, the number of links to be determined.
