So these controllers are a little flexible with their programing and inputs they receive it appears?
Yes, if you get the 3 wires for pedal sensor oriented correctly, then the controller allows you to adjust for the different signals that would come from the pedal sensor.
The pedal sensor pulses a signal as the magnets rotate past the hall sensor.
Sensors have different amounts of magnets on the rotating wheel, and you want the ebike to power up when the pedals are moved forward but not when you move to pedals backwards.
The KT controller allows for a signal from any pedal sensor to be used by adjusting the input settings on your KT display. (But you want the KT LCD 3 or newer to have that adjustability in the display.)
Or, you could replace the the pedal sensor with a standard KT pedal sensor and it will just plug right into the controller and work.
But, replacing the pedal sensor most likely involves removing the crank arm to get it off and you'll need a crank arm puller.
The throttle can be easily and cheaply replaced and will plug right into the KT controller so you don't have to cut and splice wires and connectors from the old throttle.
It looks like your brake switches have an SM plug but it's easy to cut and splice the two wires into the connectors on the 4T1 cable.
			Good , does it take any special equipment to be able to set these parameters?
No, just a voltmeter to check the wires to get the orientation correct.
But you can probably just trust the color code.
Red is positive, black negative, and the third wire is signal,.. Usually.
			If I understand/interpret what you are asking correctly, this specific controller is Completely potted!
Oops, I meant at the controller, not in the controller.
			Again I can adapt plugs, but hoping to find a direct replacement or plug and play adaptor if possible, understanding that May not be possible, but searching for that type of solution if it exists.
Being as your connectors won't plug into the standard SM version of the KT controller, then there is little advantage of using it other than having all the wires easily visible and identifiable.
Keep in mind that the 3 phase wires are ALWAYS matched to the 3 hal sensor wires.
Yellow with yellow
Green with green
And Blue with blue
Since the SM version of the KT controller isn't plug and play, then the waterproof plug version would be the easiest approach.
You just delete the old controller and the motor cable will just plug right in. (you may need an extension, as
@harryS  mentioned)
Then you've just got the PAS sensor, throttle, brake switches, and battery to connect.
The replacement display will just plug right in.
I think that finding an exact plug and play replacement controller will be difficult to find?
I wouldn't even know where to start looking?
			Grateful for any help, just so that clear!
No problem.
This is kinda fun.
Here's a high power motor extension cable for reference,..
Having the motor connections being plug and play makes things a lot easier to install.
