rotarypower101
 - USA
Possible anyone can identify this controller visually, or from the clues included with this post?
There seems to be NO marking or indicators on the controller as to the make or manufacture or even critical details to assess compatibility with a suitable replacement.
Where can I get direct replacement parts for a "safecastle breeze pro"?
Think I have a bad controller (tests open on each motor output and battery output with fluke multimeter) based on this video.
Does anyone know where to get help/assistance selecting a replacement controller for a 750W bike with bafang motor with 48V pack?
This is the manual specs/controller schematic if at all helpful.
I think it has the black SM connector plugs for the signal and low power?
It runs a a 6 wire sensored output and bullets for the bafang motor. (do I need to get a controller explicitly for this type of hub motor) Is there any difference between brands and protocols?
And this type of UI mode controller. How do I select a compatible motor controller with this UI mode controller? Is it possible to update to a info/data rich replacement if a direct plug and play substitute cannot be found? (Its for my aunt Im trying to help, so not opposed to upgrading the display if I can do it economically)
How do I select a controller that works with the existing sensors and UI? (is there any standardization I can test of the components)
What details do I need to confirm or get right to make sure a replacement controller is compatible?
Anything I can check, confirm or photo and report back here to get better help?
I am able to change out connectors if required, but would love to get a direct replacement if possible. Or at least one that was UNAMBIGUOUS with color codes and schematics to match.
Anything I should be aware of that might cause this to fail rapidly even if it is the controller that has failed, and the controller is replaced? Anything to check first before proceeding with a replacement?
Would REALLY love some clear decisive help and advice how to proceed and finish this repair project .
Thanks for any help!
