SOLVED!!!! The clunky pedaling was due to the 52T front chain ring. I put the original 42T back on, shortened the chain (stock bike was 52T) to fit and it works beautifully with no clunky pedaling no matter the cadence! Thank you all for your suggestions!!!!
I added a Tongsheng mid drive to a Tern Short Haul bike- its a 20" wheel, changed to a 52 front chain ring and 155 mm straight cranks. Not using speed sensor or brake cut offs.
This is my first ebike, first mid drive.
Noticed "clunky" pedaling from the start. The best I can describe it is- some resistance then feels like it slips when pedaling=clunky, on PAS 1 and 2.
At a higher pedaling cadence, it improves somewhat but still feels a bit "clunky".
I thought this is how it just is but very recently tried PAS 3 and 4- what an amazing difference! No more clunky pedaling no matter the cadence. Just smooth pedaling and incredible bionic legs!
I understand PAS 1 is minimal assist and imagined I would mostly be at PAS 2 with occasional 3 and 4 for boosts but the pedaling is so smooth at the higher PAS levels I don't want to go back.
For those with stock Tongsheng experience- do you experience some pedal clunkiness on PAS 1 or 2 too and just ride at higher PAS levels?
