Need suggestions for tire replacement
Yes, the Shinko tires are about twice as heavy as the stock ebike tires.
They are also thicker, much more heavy duty, and pretty much negate the use of/carrying-on-the-ride these following items: a flat repair patch kit.. multiple tire levers.. portable air pump (or co2 inflation cartridges).. an extra inner tube.. the installation of aftermarket TANNUS, MrTuffy, etc. inserts/protectors. And don't forget about that wrench which is needed to remove/install the wheels axle nuts. It all adds up. Plus, when you total up the overall weight of all the items that I have just mentioned, the "weight increase" overall, is nil.
I haven't needed to carry/use any of the aforementioned items on my almost daily 50 mile ebike rides since Sept of 2018. I ride to ride-- not to repair/do trailside maintenance.
In the case of a heavy duty hauler like the Xpedition ebike, the SHINKO motorcycle tires/tubes (with SLIME) are by far the best way to go.
Also, if you have a local LECTRIC ebike dealer: at the time of sale/purchase ask to have the stock/original tires/tubes swapped out for the SHINKO tire set-up (items which you will purchase separately). The dealer can then keep/resell the stock items. Everybody wins. Life is good.
Holy smokes 3/8" tall knobby now knowing how tall the knobby is time to get studs
On Amazon marrkay ms100 studs almost 200 pcs in tire
I'm pretty sure at 28mph that 8oz of slime in the tire is not an issue. But to fill enough in the much larger car tire to be effective guessing 32oz at 70mph is likely why it's not recommended for cars.
That, and much more heat. The stuff probably boils or something.
I would guess that Slime or FlatOut would puddle enough in an auto tire to cause a huge imbalance at speed.
What are the load ratings of these 20" x 3" bicycle tires? It looks like the Lectric XPedition can carry 400+ pounds on the back tire. The moped tires that size aren't rated for that high a load.
