After pedaling to my "Silver Sneakers" walk this morning, I mounted up for the return, noticed my seat felt wonky, and was startled to see it fall to the pavement. Had to walk the bike a mile or so to get it home. So glad it wasn't farther, and that it didn't happen in the middle of a busy intersection. The cause? A broken seat bolt.
So how did this happen? My guess is that, because I have set the seat back as far as possible (for irrelevant reasons having to do with making it fit me and my riding style), this made it function as a cantilever, which put a strain on the seat bolt, which eventually fatigued and sheared off. I fortunately had spare seat mounting hardware at home, and was able to fix it in the shop.
But now I'm thinking about how embarrassing that could be if it were to happen again in the middle of an intersection. One way to avoid a future occurrence would be to use a larger bolt. Since the seat mounting bits are aluminum, it should be easy to drill out and tap for a larger bolt (I'm guessing it's metric, though it looks a bit bigger than 6 mil. but smaller than 8 mil.) I also think it would be wise to use a hardened bolt, grade 5 or 8, as these are much tougher than standard ones. My local hardware store has these, and when re-tapping the hole I can go SAE or metric as needed.
I'll report on how this works out after I've done it.
