GAJ
- USA
- City
- Santa Rosa, CA
that I will actually be getting MORE exercise on the e'bike than on my other bikes.
Not something I expected at all but hills here in Sonoma County, CA that once just taunted me, (ie. any hill whatsoever), are now attainable as are longer distances/sights.
Zero range anxiety as at 33lbs it is actually easier to pedal unassisted than my Hybrid Tired Kona Nunu MB which also weight around 33lbs.
Higher grade of components must be the reason for that.
Feels lighter and more nimble than the MB due to the aluminum frame and carbon fork I suspect.
I thought that age 66 getting an e'bike was a sign of resignation dooming me to couch potato status on 2 wheels.
Not so; quite the opposite.
Took four months to realize that the fork harshness over larger bumps was due to none of the three helper springs included were actually installed on the bike by the LBS which is odd.
Took a little over five minutes to install the helper spring.
Loosen pinch bolts on steering stem.
Use your fingers to unscrew the finger tight cover on top of the stem.
Remove stem and attached handlebar and place carefully on front wheel, (used a bungee cord to keep it there).
Use an adjustable wrench to remove the cover for the spring compartment.
Drop in the spring, (I attached it to the cover for proper placement), and tighten the spring cover with adjustable wrench to "tight" but not overly so.
Replace stem/handlebar and align.
Replace stem cover with fingers.
Tighten pinch bolt on steering stem.
I used the medium spring (black) as the soft spring didn't seem to offer any resistance to even a finger squeeze while the hard spring only offered resistance.
I think that will take care of the harshness/bottoming out when going over such things as railroad tracks.
