PedalUma
- USA
- City
- Petaluma, CA
Probably more like 35 pounds or 36 is realistic depending on the size of the bike. Here are three coaster brake three speeds, two of them are very similar but one of those has a Union Jack and gravel tires, the other has a shorter Books saddle. Steel in the real world is very fast because it absorbs road noise and jar so the rider is more confident while going fast.Very interesting custom make, PedalUma. For the OP, guessing that the power output wanted and battery weight would normally not allow a sub 50 lb bike with that much power to be realistically achievable.
IMO, unless you don't want to do much of your own pedal effort, 250 or 350 watts is generally more than enough. In my case, I can regularly (every ride) get up 7-10% grade hills fairly easily, and with effort up 12+% grades ... with a single speed carbon belt 350 watt (500+ watt peak) high geared (64x20) Ride1UP Roadster v2 ebike, about 33 lbs stock and 42+ lbs with addition of external battery and fully-loaded with tools, food and extra water.
For @PedalUma, would it be feasible to take a standard 3 speed Shimano IGH analog bike and convert it to an ebike ... and be able to keep it well under 30 lbs and have reasonable range? TIA.
