Good sized hill? Measurements please? My geared hub motors easily handle 330 lb gross up 15% grades, up to 100' long. I have 3 or 4 grades like that on my weekly commute to summer camp, plus 71 others. 15% is a 7/8" rise on a 6" spirit level.
In 2021 I wanted to measure a grade to calculate how much power my hub motor was providing. I used a level stick to sight a spot on the road uphill, measured the height of the stick from the pavement where I stood, and measured the distance to the spot I'd sighted. (Actually, grade is rise over run - tangent, while I was measuring rise over hypotenuse - sine, which on roads is practically the same.)
Later, I found a short grade that would keep me rolling at a constant slow speed. If I could measure the grade, I could calculate my rolling resistance, but sighting with a stick doesn't work very well where the rise is slight. I used a 4 foot level. My results were inconsistent. I guess if I'd waited until dark and shined a low flashlight along the pavement, shadows would have told me that the grade wasn't constant.
Then I discovered that laser levels can be small, accurate, and cheap. At first I thought it was dangerous to look at a laser. That may be true of pointers, but levels spread the energy along lines. I'd set up the laser near ground level at a landmark at the top of the grade, use a metric carpenter's tape to measure from the beam to the ground, and walk down the hill, laying out a 100 meter fiberglass tape. I'd turn, look toward the level, and crouch until I saw the flash of the laser. That would tell me when I was getting close to the point where the beam was at eye level. Before I got there, I'd spot a convenient landmark, extend the carpenter's tape to the ground, and crouch to see at what mark I saw the laser flash. The difference between the measurements was how far downhill I'd come, and the fiberglass tape showed the distance. I'd write that down and set up the laser to measure then next segment down the hill.
Sometimes I'd bring a short stepladder. Being able to raise my eye level a couple of feet meant I could measure longer downhill segments. I have been using a camera tripod for the level. The minimum height is 18 inches, and having the beam 18 inches off the ground means I can't see it from as far down the hill. It occurs to me that if there is no grass in the way, I can set the level at ground level, for example on a compact disk shimmed with playing cards.
If I know the grade, I can calculate how many watts I'm producing to climb at a certain constant speed. (Any headwind can add a lot. Most of the pavement around here is bumpy like gravel, so rolling resistance is significant.)
