Hydraulic brakes XP 2.0
lectricG
What is the best easy to install hydraulic brakes for my XP 2.0
That would be mechanically activated hydraulic brake calipers.
That's what we did. No need to rewire. I think the new calipers cost 30 bucks on amazon. Much smoother and less noise. It was so long ago, I forgot exactly what brand but I'm sure a search up top will lead the OP to the promised land. Here I did a quick search...
I installed the Zoom Xtech HB100 cable operated hydraulic brakes on my Lectric XP 2.0 step through. At the same time, I installed new 180mm front and 160mm rear discs and Jagwire cables and cable housings. Everything came from Amazon. Easy, inexpensive project and good results.
Waiting for cables $27 in Amazon
Installed used the bottoms of stock brakes to keep same height had to pull the front caliper towards the fork cause it was playing a tune on the spokes
That is one of the reasons I installed a 180mm brake disk on the front of my XP 2.0 with the Xtech calipers. That places the front caliper radially outward a little bit so the Xtech caliper does not interfere with the rotating spokes.
