Wow I missed this original thread and user's issue. And this one too. My excuse is I was in the Poconos on a business trip (really!)
@officerdare's problem *really* sounds like wonky settings inside the motor. I wonder what are those settings? Best would be screen shots of each of the three settings screens. Pretty confident we'll see a smoking gun in there.
52v battery is not any sort of issue. The only thing a 52v battery does is give some extra usable voltage. 14S packs have a peak of 58.8v and 13S packs are 54.6v. Increased speed is negligible and what little is there only lasts for a short time. The reason you go 52v is to stay in the usable voltage range of a 48v system for a longer period of time. As for problems caused by kaka battery manufacture... yeah sure. But that is a problem of cheapskate consumers, not the battery platform.
Absent a response from
@officerdare, the version 2 in the linked follow-on article (page top) to the one below will yield pedal assist output in the
450w range
on level 9. Six to eight amps continuous on flat ground, but that is a really big bike, so something a little less ginormous might eat fewer amps.
I have a mountain bike with the same settings that I need to ride tonight. Oddly enough I am checking the amp output of both bikes to make this specific comparison between the two.
That 450w is on a 52v battery and since the motor retains the 30a output, leaves full output/throttle available on request. It also gives a slow power rampup, and a near instant-off when you stop pedaling. Keeps just a skootch in case you want to use that split second of barely powered rotation to complete a gearshift.
