Have a Turbo Vado 3.0 that needs a new shifter cable. Does anyone know if I can feed a new cable through the old casing at the shifter or if there are breaks in the casing where I'll need to take the motor cover shield off? Thanks
*Maybe* but likely yes if the ferals and housing are not damaged. No breaks in the housing/casing. If you have to replace everything then tape the new cable/housing to the front of the old housing so it is the same diameter and pull it through the frame. Look and think before you do this.
