mschwett
 - USA
I don't pretend I'm smarter than Shimano and SRAM; or Magura, Tektro, and TRP too; they know their brakes.
Some hydraulic disk brakes can be centered by loosening the caliper bolt, squeezing the brake lever and re-tightening the bolt. High end brakes such as TRP Zurich are totally fixed. As the matching wheel must come on a thru-axle, the central position of the rotor between the pads is guaranteed.
Why reinvent the wheel? Bikes are not cars.
not exactly guaranteed…. different cassette and freehub configurations along with different amounts of torque on the through axle can absolutely move the rotor. rotor thickness and alignment also varies slightly brand to brand and of course, over time. if you have two wheelsets on a disk brake bike, you’ll see each time you change them that the alignment is slightly different. loosening the caliper fixing bolts, braking, and then tightening the bolts while braking as you note usually does the trick. the tolerances on these brakes are tiny, very different from cars.
all my brakes, from cheap no name on the vanmoof to mt200 on the sirrus, shimano GRX on the creo and the latest shimano dura-ace on the aethos have occasionally required this adjustment. then again, we have HILLS here!
