dollarbin
Yesterday I was trying to insert my key into the battery lock on the bike (green arrow), and in my haste to get on the road I accidentally briefly put the key into the uncovered battery charging receptacle (red X). The metal key made a short across the two terminals and there was a pretty good spark, but no other visible damage. The battery was fully charged and I was able to ride my bike 16 miles home with 35% battery power remaining. When I got home, however, I plugged in my bike to recharge as usual and the battery did not start to recharge.  The light on the charger stays green indicating that it is not charging the battery, either on or off the bike. I assume that when I shorted the connector, I have burned out some component of the charging controlling hardware in the battery.
After a phone call to my LBS and a little online reading, it seems like this is not an uncommon occurrence. Unfortunately person on the phone at my LBS did not think this was something they could repair other than selling me a $1,000 replacement battery. Does anyone have any experience fixing this kind of accident without replacing the whole battery? Is there a fuse or something in there that can be replaced? Or a company that will replace the failed board in the unit? Or should I just bring it into my bike mechanic and see if they can get a solution from Specialized to fix this?
Clearly I'm 100% responsible for this, but it also seems like a design flaw that a moment's inattention bricks a $1K component without any circuit protection.
Whether this is a cheap or expensive lesson for me personally, consider this a public service announcement to be vigilant about replacing the charging port cover as soon as the bike is unplugged.
