Nvreloader
Western Nevada
- USA
I have this paved road, I have tried twice, both times I failed to make it,
all information is confirmed via GPS and Google Earth measurements.
Information on this road, 6.25 miles long, 971' elevation gain,
starting point is at 4165' elevation (GPS reading of 41*13-32N/118*22-27W) and ending point is at 5136', (summit) (40*12-09N/118*16-22W), google earth sat view readings,
one long steady uphill climb with approximately a 29% grade.
I am using my new Wart Hog Ebike MD 750w dual battery, 48v/30ah,
which I have had just about 30 days now, with the following gears.
This info is from Bikonits site,
Sram X-5 - 9 speeds, DNP 13T-34T with KMC Chain etc.
The tooth count is as follows,
Big main peddle gear = 44T
Big gear on back sprocket =34
next smaller = 30
next smaller =26
next smaller =23
next smaller =20
next smaller =17
next smaller = 15
last smaller =11
I used the 17t, 20t and 23t, starting in 17 and then ascending in gear choice, as it get steeper, and I am running out of leg power, tire pressure is 30 psi, no wind/weather conditions to contend with.
Both times it feels like the bike's battery is out of juice, using the Eco setting, via hard peddling, until I can't peddle any farther, I have not and will not use the thumb throttle, just using Shanks Mare power.
I have found out since these failed attempts, that I have a BAD battery that WILL NOT hold a charge, so I only have 1 battery to explore with, until the new one gets here.
I will attempt another go at this hill, after I charge the 1 remaining battery back up.
IS it me or the bike's fault, yes, I am a new rider, (75yrs old), but I can walk 10-15miles per day, the bike weighs right at 85lbs, loaded with the pack/gear and I weigh in at 200 lbs.
or am I doing something wrong?
Your thoughts and suggestions.......
Tia,
Don
next smaller = 30
next smaller =26
next smaller =23
next smaller =20
next smaller =17
next smaller = 15
last smaller =11
Tia,
Don
