Ok - to get totally into the weeds, does it make sense then that one strategy would be to keep a consistent “high” cadence, keep support low, but have max power high so that it is giving you power most when you need it?
cadence has a bit to do with what kind of rider you are - but generally, yes, higher cadence is better. 90rpm is a good target for most non-elite road cyclists. the specialized SL motors are tuned to produce peak power between 70 and 100 rpm, although peak torque occurs a bit earlier, around 60rpm. some riders like to "grind" or push harder and slower in a lower gear, some like to "spin" or push less hard but very fast in a higher gear. the specialized motors allow either behavior
your strategy of keeping support low but max power high can be a good one, although it results in inconsistent and unpredictable battery usage. the harder you pedal, the more battery you use. if you're pedaling hard to go fast (rather than uphill) you'll eat battery very fast without actually going much faster since wind drag is the CUBE of speed - it's 8 times as much at 20mph as it is at 10mph. weight matters almost none once you're already moving.
personally, my preference is actually for the bike to provide a relatively constant and low amount of power. my typical output is 180-240w, and for long climbs or very bad headwinds i like a boost of 60w or so, so i set my eco mode to 15/25.
.15 x 1.8 (max SL assist) x 180w (low end of my cruise power) = 48w
.15 x 1.8 (max SL assist) x 240w (high end of my cruise power) = 65w, but capped at 60w
.15 x 1.8 (max SL assist) x 500w (i get out of the saddle and push hard for fun) = 135, but capped at 60w. i actually DON'T want the bike to use 135w in this scenario, unless i've pushed the button to switch to turbo
i know that with these settings, the battery usage will be around 60w on average, assuming i'm pedaling. i typically average around 16mph unassisted with hills or 18mph on flats, that extra 60w would probably yield an average speed of around 20mph, the 320wh battery would last around 4.5 hours (not 100% efficient and you can't use every last watt!) for a range of close to 100 miles.
i leave my turbo at 100/100, virtually guaranteeing the full 240w of power any time i'm pedaling. i actually use this on a nearly daily basis when i ride home from work late at night up a 20% hill. low gearing and 240w make quick work of it.
