Chainring size
tallpaul
About to get a new 2022 Turbo Levo and I was wondering if it is possible to put on a larger chainring that will not screw up any of the sensors, Mastermind, or other electronics on the bike?
I can get either a 36T or 38T for it.
Chainrings don't have any effect on the sensors. You should be able to change it like any regular bike. Just make sure that the number of links on the chain is right.
First check whether the bigger chainring would mechanically fit the frame, especially if it would not hit the chainstay (I cannot say because I don't own a Levo).
I can measure the outer diameter of a 104 BCD, 38t chainring for you.
Thank you for your replies. So it seems that the only obstacle in going bigger is the potential for clearance issues.
I found this today:
  • Workbook_Turbo_Levo_Gen_3_2022.pdf
