Turbo Vado SL 2 6.0 - turns itself on when off and unattended [SOLVED]
I'm the person who started this thread back in February. It's interesting to see how long the discussion has lasted. I have some new information, as of this morning, which adds some useful information.
After nine months of my bike NOT randomly turning itself on, I opened my garage door last night to see the headlight and taillight shining brightly. Oh no! As we've all observed, the display was also on and the clock showed an incorrect time. This morning, I had a very useful text exchange with Specialized Support which explains exactly what's going on. Not only that, it explains why the behavior is considered "normal." It's still not clear to me why the display battery has charged sufficiently for the past nine months and why it didn't when I rode last week. One of life's little mysteries?
As for the bike turning itself OFF after the display has charged, I've now tested twice turning the bike on and letting it sit. After several minutes--I didn't pay close attention--the bike powered itself off. One last note relative to what the tech guy said, I DO use Find My on my iPhone to track where my bike is, so perhaps that's what caused the bike to go on yesterday.
To answer Jeremy's question, I would absolutely buy the Turbo Vado SL 2 6.0 again, and would highly recommend it to anyone looking for an "e-bike that doesn't look like an e-bike." It has ample power to climb any hill, great components all around, is light enough to easily lift onto a bike rack, and is just plain fun.
Here is a transcript of my text exchange with Specialized Support this morning:
Turbo Vado SL 2 6.0 Carbon
ME:
I purchased this bike in September 2025. In November 2025, I discovered that the bike was turning itself on when unattended. This happened randomly when the bike was in my garage (which is cool and dry). The bike has never been wet. After several trips to my bike shop--First Mile Cycle Works--they and Specialized determined that the motor wiring harness needed to be replaced, which they did in January 2026. That did not fix the problem, so Specialized then sent a new Mastermind Display in February 2026. That fixed the problem, until now, nine months later. The bike is once again turning itself on while sitting unattended. When this happens, the display and lights come on, and the clock on the display shows an incorrect time. When I open the Specialized app on my iPhone, it connects and the clock resets to the correct time. I have to say that I was quite startled to see the bike turned itself on after so many months of perfect performance. I would appreciate a follow-up with your suggestions on what I should do now? Does the bike need yet another new Mastermind Display? Thank you.
SPECIALIZED:
Hi, thanks for reaching out! The bike is turning itself on to charge the internal battery of the Mastermind display. You can reduce the frequency of the bike turning itself on by periodically charging the display itself with a USB-C cable that will plug into the side of the display.
ME:
Ok, thanks. I assume I can use the same USB-C cable and charger I use for my iPhone. Is that correct?
Last Thursday, I rode the bike for four or five hours, so I would think that would have fully charged the display battery. It was late yesterday that the bike turned itself on, only four days later. For the last many months, my regular rides have kept the display battery charged, so why would that change all of a sudden? Might something be wrong?
SPECIALIZED:
Yes you can use that same cable and charger. Riding the bike will typically charge the display however if the internal battery is low enough it would not receive enough charge leading the bike to turn itself on to charge.
ME:
Well ok. It seems odd to me that after nine months this should start happening again, but I will live with it and let you know if the situation gets worse. As always, thank you for your help.
ME:
Follow up: I understand that the bike may turn itself on to recharge the display battery. But, shouldn't it turn itself off once that battery is charged? I'm thinking of a situation where I may be on vacation, with the bike in my garage, and it turns itself on when I may not see that for several days or longer. That's not a good situation.
SPECIALIZED:
The bike will turn itself off!
ME:
After how long? I have not seen that.
SPECIALIZED:
We don't have an exact timeframe, but it is whenever the display is sufficiently charged.
(See attached image)
Well that's an admission from Spesh ! Maybe the USA branch should connect to the European branch & give them this info 'cos they're seemingly not aware !
Would be good to make this a BIG mention in the handbook too...
As to Jeremy - yes my SL2 6 Carbon is a massive improvement (imho) to the SL1 4 or 5.
So end of thread...??
