I've got a stealth bomber clone. 72v with 8000w. It has a Sabvoton mq con 72150(m) controller. Generic no brand name full twist throttle from ebay/China. Panasonic battery.
So here's the problem:
~No throttle response and no throttle response from the pedal assist.
This is actually the second time I've had this problem. Sort of. The first time was slightly different. The first time this happened it was temperamental. Either no throttle at all or pedal assist at all or I would give it a little throttle/pedal and it would go to full acceleration uncontrollably and not stop until hitting the brakes thus activating the cutoff. Either one or the other with no in-between. Either full throttle or no throttle and it was like it had a mind of its own. And when it would go into spastic mode, the brake cutoff was the only thing that stopped the motor from spinning, shy of cutting the ignition. But soon as I let off the brake the bike is going full throttle again uncontrollably. The first time this happened I opened her up and I thought I had found a crimped wire. But while I had the bike open I changed the half twist throttle to a full twist one, and low and behold when I put the bike back together, the problem was fixed. So whether it was the throttle or what I thought was a crimped wire, was left undetermined specifically.
~Well, now I've just got no throttle and no throttle response from the pedal assist.
I've got a green flashing light on the controller that flashes 30 times. Well, it flashes continuously, but after 30 flashes there's a slight pause. So I'm assuming that's 30 flashes.
If I disconnect the hand throttle the green light stops flashing. And if I keep the hand throttle disconnected and turn the bike off and back on, the pedal assist returns to function perfectly. But then if I reconnect the hand throttle (with the power still on), guess what, the initial problem starts again with the motor spinning uncontrollably as I mentioned above when I had the "first" issue. Brakes do stop the motor via the cutoff, but as soon as I release the brakes the motor is at full acceleration uncontrollably, just like the first time. If I then disconnect the hand throttle (with the power still on), the motor stops. But if I barely touch the connection together again, the motor starts again uncontrollably. So I turn the bike off. Reconnect the hand throttle. Start it up again. No throttle and no pedal assist. Repeat the process and it does the whole thing I just explained over again.
Is the problem the throttle or the controller? Or is there something wrong in the parameters settings? If it's the throttle, why do I keep burning them out?
SOMEONE OUT THERE PLEASE HELP?!?!?!?
