Bjr49000
- Europe
Hi,
I have a BBS02b kit installed on my bike since a while. Recently I had problem with motor and display switching off abruptly.
I'm trying to understand where the problem comes from.
It seems to me that the problem is battery voltage drop too much under load.
I would like to know if the switch off security features is triggered by the BMS of my battery or by the 'Low Battery Protect' that you can set when programming your Bafang motor.
When my bike switch off, motor and screen go off. To power it on, I have to set the battery switch off and on to switch on the bike from the controller again.
Is there a difference in how motor voltage cut-off and battery voltage cut-off works ?
From what happen, can you tell if it is the BMS or the motor ?
Thanks for answers ! First post
