iceclimber
- USA
Cyrusher lanke S700 display
The behavior is - while under power, using the throttle under setting #1 or any # or peddling - the power cuts out and the display turns off. If I power cycle the battery, the display comes back on. I am able to select a power setting and or peddle and it may work for a while then cut out again. Sometimes it's immediately, other times it takes a while. If the power setting is set to zero, it doesn't happen. I've tried to isolate it to the throttle and jiggled wiring looking hunting for a short, with no luck.
Any ideas of where to look for a short or connection problem ?
