Cycle Analyst V3 question
Randy S
I have PhaseRunner for the Controller
Seeking same for CAv3
I assume you're asking about the CA setup utility program to change settings and do firmware updates?
https://ebikes.ca/product-info/grin-products/cycle-analyst-3.html ... and scroll down.
The TRS cable may sometimes require a driver (but most of the time under Windows the OS will see the USB TRS cable as a known device). If not there are cable device drivers on that same web page. Make sure the cable is visible to the OS before moving on to the apps for the PhaseRunner or the CA (plug the cable in and you should get both a "good USB" chime and the TRS device will show up as a device in the Windows device manager. The driver for the cable will also create a com port #, you may need to reference this number when you setup the apps.
The PhaseRunner Suite allows you to change the settings of the PhaseRunner and BaseRunner controllers.
The CA Setup Utility allows you to change the settings and firmware on the Cycle Analyst.
All the download links and information are on the Grin website.
I think I didn't word my question correctly. I used the PhaseRunner and made necessary changes. Some changes can only be made in the CAv3 - my attachment shows these changes can be made via computer (as opposed to directly in the CAv3). So I am looking for the software/program that will read the CAv3 (just like PhaseRunner did for the controller).
And that's exactly what RunForTheHills and I gave you links for ... in my case it's the first link.
