TWB503
- USA
Before you say “just buy a bigger battery”, well that’s no fun, is it?
I want to put a generator system on my eBike (will this actually happen? Probably not, but I still wanna get some opinions on it).
The two options I have are this:
1) Buy a Honda GX35 engine, it only weighs 7.6 lbs, and then find a way to generate power from the rotational output (probably have to generate a high amperage 12V power and then use a boost converter to take it to the 42V I need). It has a 1 kW mechanical output, which if we have (I’m guessing) 50% mechanical efficiency from shaft to charge, gives us about 500 watts, which is more than what I need (I probably could get by with 250W, so I could run the generator at half throttle?)
Additional info-
.63 litre fuel tank
1.0 kW @ 7,000 rpm
1.6 Nm @ 5,500 rpm
0.71l/hr at full throttle
Advantages-
- Lighter
Disadvantages-
- Will require a lot of work (but that’s fun... right?)
- Probably louder
- I have no idea where to find a generator
- May have trouble fitting to bike
2) I own THIS
So what if I put it on one of THESE!
In theory, this would work, since it weighs 46 lbs, and a lot of these bike racks claim to be able to hold up to 60 lbs.
This thing is as quiet as “52 dBA” and can last “up to 12 hours” on a 1.2gal tank.
Advantages-
-Quieter
-More efficiency from fuel to battery
-Can always upgrade the charger if needed
-USB ports (my bike HAD a USB port, but now it doesn’t...)
-Cheaper (in my case, but only because I already own the generator)
Disadvantages
-Substantially heavier
-Messes up weight distribution
-Might break the mount if I’m not careful
So if you were to build a generator for your eBike, which one would you do?
Additional info-
.63 litre fuel tank
1.0 kW @ 7,000 rpm
1.6 Nm @ 5,500 rpm
Advantages-
- Lighter
Disadvantages-
- Probably louder
2) I own THIS
Advantages-
-Quieter
Disadvantages
