duuuuuuuude... why you do this to me ?Yes - Pushkar now has / will soon have the ability to 3d print cases and he has a US battery source for custom packs.
| Grouping | Component | Manufacturer | Notes | |
| Frameset | Frame | WW Custom TI Frame Based on Salsa Blackborow GX Eagle Geometry | ||
| Fork | Manitou Mastodon Pro Ext 100mm (15mm x 150mm axle) | Accommodate 26'x4' to 26'x5' tires | ||
| Front / Rear Fenders | WW Custom Fenders | Accommodate 26'x4' to 26'x5' tires | ||
| Trailer Mount | Research Hitch Type to Carrier | |||
| Seat | Saddle | Ergon ST Core Prime S/M | ||
| Seat Post | Kinekt 3.1 Carbon Fiber Seat Post | |||
| Seat Collar | Review Options | Goal is Theft Prevention and Easy Adjust | ||
| Headset | Handlebar | Cruiser Handlebar - Review Options | Upright Position / Pedal Forward | |
| Stem | Kinekt Suspension Stem | Overkill??? | ||
| Headset | Integrated Headset - Review Options | 1 1/8" Head Tube | ||
| Grips | Ergon GP 1 to 5 - Review Options | Leaning GP2 | ||
| Misc. | Bar Plugs, Top Cap, Spacers | |||
| Drivetrain | Motor | Bafang Ultra with Archon X1 controller 1000W | ||
| Display | WW Custom Large Display | |||
| Battery | Custom 52V 29ah Battery Case and Samsung 21700 50e v2 Cell Pack | |||
| 2nd Battery | Ability to Add a Rack Battery in the Future | Overkill??? | ||
| Belt | Gates Belt Drive Black - Belt Length? | |||
| Rear Sprocket | Gates CDX EXP - Size? | |||
| Rear Hub | Kindernay XIV Fatbike 197/12 CL (216mm/203mm) (32h) (16t) | Issue Using 197/12 with Gates Drive? | ||
| Shifter | Review Options | Goal Single Shifter on Drive Side | ||
| Throttle | Mount Drive Side | |||
| Crankset | Crank Sprocket | Gates CDX EXP - Size? | ||
| Crank | WW Carbon 165mm | |||
| Pedals | Crankbrothers Stamp 2 or Shimano PD-M8040 | Leaning Shimano | ||
| Brakes | Brakes | Dominion A4, Quad Piston | Regular / SFL Lever Differences? | |
| Rear Disc | Magura MDR-C CL 203mm or 180mm | |||
| Front Disc | Magura MDR-C CL 203mm | |||
| Wheelset | Rear Hub & Sprocket | See Drivetrain | ||
| Rear Rim |
| Spokes | Berd Black PolyLight Spokes | |||
| Tire | 26"x4" Dillinger 4 or Kenda Juggernaut Pro 26"x4.5" | |||
| Front Hub | Onyx FAT ISO-150/15mm CL Thru-Bolt (32h) | Powder Coat - Black Aura, Clear or Black Widget? | ||
| Front Rim | 26" H.E.D Cycling B.A.D (15x150mm) (85mm) (32h) | |||
| Tire | 26x4 Dillinger 4 or Kenda Juggernaut Pro 26x4.5 | |||
| Misc. | Reflectors, Tubes, Stems, Nipples | |||
| Lights | Front Light | Wired in Addition with Lezyne 1800i | Review Options - Wired | |
| Rear Light | Wired Rack Mounted in Addition with Lezyne KTV | Review Options - Rear Light with Braking | ||
| Aux Power | (2) 5w 3-Pin Auxiliary Power, Future Expansion (i.e. Horn) | |||
| USB Power | Cockpit Phone Charging | |||
| Accessories | Horn / Bell | Locate on Non-Drive Side | ||
| Lock(s) and/or Alarm? | Review Options | Location Seat Tube | ||
| GPS Tracker | WW - Research Details | |||
| Charger | WW 10A Charger | |||
| Chain Guard | Belt Guard | Only for Aesthetics | ||
| Kickstand | Center Stand - Review Options | |||
| Rear Rack | WW Custom TI Rear Rack, Bolt | |||
| Front Rack | Review Options, Bolt | |||
| Rear Rack Pannier Bag | Review Options | |||
| Helmet | Review Options | |||
| Bottle Cage | Review Options | Location Down Tube | ||
| Cables/Housing | Cables/Housing | Brakes, Display, Kindernay, Lights, Power, Throttle, Misc. | ||
| Misc. | Cable Guides/Clamps |
That is a big reason for choosing this frame style.Looks like there’s plenty of room behind the seat tube of that copycat Salsa frame for one large-capacity battery.
This is an awesome build. Will you be posting how much everything will cost?UPDATE 2 - Component List (Draft)
Building the list took longer than I expected especially since I chose Kindernay over Rohloff. Feedback is welcome.
Grouping Component Manufacturer Notes Frameset Frame WW Custom TI Frame Based on Salsa Blackborow GX Eagle Geometry Fork Manitou Mastodon Pro Ext 100mm (15mm x 150mm axle) Accommodate 26'x4' to 26'x5' tires Front / Rear Fenders WW Custom Fenders Accommodate 26'x4' to 26'x5' tires Trailer Mount Research Hitch Type to Carrier Seat Saddle Ergon ST Core Prime S/M Seat Post Kinekt 3.1 Carbon Fiber Seat Post Seat Collar Review Options Goal is Theft Prevention and Easy Adjust Headset Handlebar Cruiser Handlebar - Review Options Upright Position / Pedal Forward Stem Kinekt Suspension Stem Overkill??? Headset Integrated Headset - Review Options 1 1/8" Head Tube Grips Ergon GP 1 to 5 - Review Options Leaning GP2 Misc. Bar Plugs, Top Cap, Spacers Drivetrain Motor Bafang Ultra with Archon X1 controller 1000W Display WW Custom Large Display Battery Custom 52V 29ah Battery Case and Samsung 21700 50e v2 Cell Pack 2nd Battery Ability to Add a Rack Battery in the Future Overkill??? Belt Gates Belt Drive Black - Belt Length? Rear Sprocket Gates CDX EXP - Size? Rear Hub Kindernay XIV Fatbike 190/10 CL (216mm/203mm) (32h) (16t) Issue Using 190/10 with Gates Drive? Shifter Review Options Goal Single Shifter on Drive Side Throttle Mount Drive Side Crankset Crank Sprocket Gates CDX EXP - Size? Crank WW Carbon 165mm Pedals Crankbrothers Stamp 2 or Shimano PD-M8040 Leaning Shimano Brakes Brakes Dominion A4, Quad Piston Regular / SFL Lever Differences? Rear Disc Magura MDR-C CL 203mm or 180mm Front Disc Magura MDR-C CL 203mm Wheelset Rear Hub & Sprocket See Drivetrain Rear Rim 26" H.E.D Cycling B.A.D (12x177mm???) (85mm) (32h) OEM Size Conflicts with Kindernay 190/10 Hub Spokes Berd Black PolyLight Spokes Tire 26"x4" Dillinger 4 or Kenda Juggernaut Pro 26"x4.5" Front Hub Onyx FAT ISO-150/15mm CL Thru-Bolt (32h) Powder Coat - Black Aura, Clear or Black Widget? Front Rim 26" H.E.D Cycling B.A.D (15x150mm) (85mm) (32h) Spokes Berd Black PolyLight Spokes Tire 26x4 Dillinger 4 or Kenda Juggernaut Pro 26x4.5 Misc. Reflectors, Tubes, Stems, Nipples Lights Front Light Wired in Addition with Lezyne 1800i Review Options - Wired Rear Light Wired Rack Mounted in Addition with Lezyne KTV Review Options - Rear Light with Braking Aux Power (2) 5w 3-Pin Auxiliary Power, Future Expansion (i.e. Horn) USB Power Cockpit Phone Charging Accessories Horn / Bell Locate on Non-Drive Side Lock(s) and/or Alarm? Review Options Location Seat Tube GPS Tracker WW - Research Details Charger WW 10A Charger Chain Guard Belt Guard Only for Aesthetics Kickstand Center Stand - Review Options Rear Rack WW Custom TI Rear Rack, Bolt Front Rack Review Options, Bolt Rear Rack Pannier Bag Review Options Helmet Review Options Bottle Cage Review Options Location Down Tube Cables/Housing Cables/Housing Brakes, Display, Kindernay, Lights, Power, Throttle, Misc. Misc. Cable Guides/Clamps
More to Follow.
Michael
None of my bizness and I won't ask but you gotta have over $10k ... possibly well above ... in this project.More pictures.View attachment 83188View attachment 83189
Yes - I have a budget and once Pushkar provides a cost I'll share on the thread.This is an awesome build. Will you be posting how much everything will cost?
Tough build choices may be in my future.None of my bizness and I won't ask but you gotta have over $10k ... possibly well above ... in this project.![]()
Ah what the heck. It's an investment.Tough build choices may be in my future.![]()
'They' say that many times a good investment is one where you get your principal back.I have two names in mind - "The Fremont" or "Overkill".
Why did you plant that seed???'They' say that many times a good investment is one where you get your principal back.You could ride this bike for a couple years and probably sell it for what it cost you ... so free ride and experience for two years. Then you could build another one with improvements from what you learned.
I would buy this bike!UPDATE 2 - Component List (Draft)
More to Follow.
Michael
I don’t hunt but I'm curious your opinion on the appropriate drive train for this activity?It occurs to my not enough coffee yet brain that this sort of bike could be quite useful to the 'hunting bike' crowd with the appropriate drive train. As well as the bike camping folks. Or touring as well. There's definitely a market. You might have to ship it however to get one sold.
Well .... it depends. Depends if you are willing to spend the big bucks for the IGH. Depends if you think one drive train or another would affect resale if reselling is anything to you. Depends on how you think regarding repair and upkeep. Me, I'm not a fan of IGHs just because I know I can't work on them and I don't really know much about them and I'm cheap that way. And of course it depends on how you are going to use the bike. If I WAS all hot for an IGH bike ... Pushkar is the only one I'd buy such from.I don’t hunt but I'm curious your opinion on the appropriate drive train for this activity?
