smorgasbord
- USA
Box's Prime 9 is a really interesting concept: Use the 12-speed dimension for the inside of the chain and the 9-speed dimension for the outside of the chain. This means the rear cog has plates that are as thin as 12-speed cogs, but they're spaced further apart. The front chainring can be any standard 12 speed chainring (narrow-wide). If they use the right materials, their chains could be very durable since the side plates are thicker.
Note that you give up shifting more than 1 cog at a time, but with 9 speeds instead of 12 you may not need to do that as often (although cresting a hill or going through a valley often require big gear changes no matter what).
I don't understand their claims about adjustment frequency, etc. My 12-speed SRAM doesn't need adjustment any more than my old 8-speed or 10-speed drivetrains - maybe even less since it's a higher quality system than I had on those bikes.
Note that the e-bike specific version of the Box Prime doesn't go down to an 11 tooth cog, just 12. They say it's for wear purposes.
