Handlebars
- Canada
1. Turn bike on
2. Hold brake lever to engage motor cutoff switch in order to prevent bike jumping forward
3. Push thumb throttle to position wanted
4. Insert cable tie into throttle canal all the way till it stops
5. Let go of brake and you're off! ZOOM!!!
6. Use brake to reduce speed or to stop
7. DO NOT FORGET THAT YOU HAVE THE THROTTLE ON when you finish your ride or whenever you let your hand off the brake
8. Remove cable tie until next time you need cruise control
Photo is throttle held in full open, cable tie is shortened but doesn't need to be. 5mm wide cable tie fits perfectly into the channel on that throttle.
