ryukenden73
The DNM A05 is adjustable, but it uses a ball pin. Which, if you are like me, who keeps on adjusting the pressure - the rubber plug has been shredded and is leaking.
I've ordered a Schrader valve rebuild kit... in the meantime, i replaced the DNM with this shock and have been testing it ...
Rated at 650lbs and it's an oil shock with an adjustable spring and rebound screw
