My Supercharger 2 Charging Port Flap falls off and is difficult to put back in place.
Lee Philipson
[email protected]> wrote:
Hi. I am having trouble with the rubber exterior charging port cover on the motor. It comes completely off when I open it to charge the bike and then it is very difficult to snap it back on after charging. It also does not sit flush if I do get it back in place. This can’t be right. What can be done to cure this issue. I am concerned that foreign material will het in the port. Thanks.
I ripped mine off and left the port exposed. Its totally worthless and shame that a 8K+ bike has a rubber flap that easily comes off and is difficult to close. I am taking my bike for tune up and will ask them if just leaving the port open is OK.
It sounds like debris/water is not good for electronics via the charging port. I found a water-proof material to make a "plug" to fit in the port - under the cover. The cover does not stay closed/sealed and I would hate to have such an inexpensive item (port cover) be the ruin of delicate/expensive components. A small inconvenience to remove the "plug" to attach the charging cable.
I have been told that Riese and Muller has created a hard plastic fix which will be available soon. Your solution is impressive.
Even Trek do a neat magnetic cover. It’s high time R&M gave everyone a free updated charge port cover. Outrageous flawed design on such expensive bikes.
