Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
In the self-styled way, I acclaim the Ergon GP3 the best bike grips ever made!
Some tips will follow:
Proper Setup
First of all, the GP3 come in two sizes. Buy the Large variety only in case you have really large hands. The Ergons might be too wide to fit your gadget-crammed handlebars, and it is also better not to change the brake lever position. If you still see the yellow interior of the grip after you have slid it fully onto the handlebar, you need to shorten the grip. Use a very sharp knife to shorten the grip -- and be cautious to not cut your fingers! (You have been warned)
No yellow part should be visible with the properly slid grip. The wrist supports should point slightly upwards. Add the bar-ends. The angle is your choice, with 30-45 degrees being the most reasonable. Tighten the screw at 5 Nm. Again: No yellow part should be visible inside!
The "normal" or "safety" hand position. Use it while riding with traffic or on crowded bike or multiple-use paths.
Modern e-MTBs sport the "1-finger" brake levers; modern commuter e-bikes have the "2-finger" brake levers. Never place more fingers than necessary on the lever. While riding in a crowded area, rest your finger(s) on brake levers in a relaxed way; you don't want to make your fingers tired but you might want to brake rather fast.
The "steering-wheel" or "trail" hand position. That's what makes the Ergons so great. You delicately rest your three fingers on the bar-end, while your thumb and little finger ensure a proper hold. You steer your e-bike as you were operating your car's steering wheel. That hand position is proper for very long rides and ensures the best control over the bike even in very rough terrain. The benefits:
The "Easy Rider" hand position. Use on a very long ride in safe environment when you are really tired. Rest your wrist and thumb on the wrist-support. The part of the palm near to the little finger shall rest where the bar-end-plug is normally located.
Falling with Your Bike
There are two survival techniques, shall your bike fall:
Proper Setup
- The hand doesn't get tired or numb (people with carpal tunnel syndrome will be delighted)
- You exercise the perfect control over your bike, especially with wide handlebars
- In rough terrain, you just tighten your grip a little bit for even better steering control
- During "washboard" sections of gravel roads, ease the hand-grip. The bar-end will travel vertically among your fingers, providing rapid-vibration protection to your hands -- especially, owners of rigid-fork e-bikes will be happy!
- Jump off the bike as graciously as Bambi would do it
and let the bike fall between your legs (It requires a long practice);
- Provided you're wearing the helmet, move your hands instantly to the "safety position" and just fall together with your e-bike. Your hands shall be on the grips and your feet shall stay planted on the pedals! Your head will probably hit the ground but it's protected. You might get some bruises. But your limbs won't get broken and the hands won't be damaged, as the latter are protected by the GP3 bar-end. Trust me: I know the best how to fall with the bike. The stains of sun-molten asphalt on my Trance E+ right-hand GP3 bar-end are the proof. The grip and my helmet took the most of the impact. And I have fallen with my bikes many times before I mastered the (1) technique
