D
		Deleted member 4210
Guest
This should be obvious but apparently its not. Seriously people, its DUMB.  If you are checking for 'wobble' in the front wheel then very likely you will GET IT.  Here's why... on an ebike, you not only have cables from gears and brakes going up to the handlebar, but also you have a wiring harness to the display, AND, you have extra signal cables going to each brake lever.  The combination of wires and cables have varying degrees of tension, and without any hands on your handle bars, the front wheel could very easily turn to one side when you let go of the handlebars. (we get it...when you were a kid with a coaster brake bike and no gears you did the old 'look ma, no hands' - you THOUGHT you were "cool." Well you are not a kid anymore and these are not cable free bikes, and are powered by motors that are pushing you likely beyond your capability if you are even remotely considering doing such a thing just to 'see what happens') .  The ebikes cables going to the handlebars could easily create a slight pull to one side or the other, and part of it also depends how they may be wrapped, or even the stiffness/tightness of one of the hydraulic brake cables.  So yes, to answer your curiosity, there will not only likely be "wobble" (which is not relevant to telling you anything important about your ebike's road worthiness), but you will also most likely wipe out and injure yourself.  So if you REALLY want to see if your ebike's front wheel will wobble (for only God knows why you'd want to do that), then go ahead completely remove all cables, and see what happens. SMH.  Anywho, this should go without saying, but may I suggest simply you keep your hands on the wheel at ALL times, head up, and eyes on the road. PLEASE !  And wear a HELMET ! (and yes I have been asked this question as a dealer)
