My white Lectric XP arrived today in good shape. After unboxing it I put it on the charger to top off the bike. I would like to know if I can ride the XP without the need for pedaling? Is so how? I have diabetic ulcers on the bottom of both feet and don't want to aggravate them.
the charger is never off unless its unplugged.My new lectric xp is due to arrive next Tuesday. The Manuel says not to leave the battery charger plugged in after battery is charged and and the charger has turned off. Is this really necessary if the charger has turned itself off?
So your saying that the battery is being charged even if the battery auto cut off has turned off.the charger is never off unless its unplugged.
no the battery cuts off the charge though it may turn on again later. but the charger is always supplying power. but with these cheap batteries it may be risky to leave them plugged in.So your saying that the battery is being charged even if the battery auto cut off has turned off.
I see, thanks.no the battery cuts off the charge though it may turn on again later. but the charger is always supplying power. but with these cheap batteries it may be risky to leave them plugged in.
This makes just about as much sense as unplugging a toaster when your toast pops up. Or for that matter unplugging your washing machine at the end of a wash cycle.the charger is never off unless its unplugged.
You would think so but a toaster work a little different then most battery chargers so best practice is to disconnect. As far as timer go keep in mind they can fail or you think you set and you for got. Ever see automatic lights fail?This makes just about as much sense as unplugging a toaster when your toast pops up. Or for that matter unplugging your washing machine at the end of a wash cycle.
To be clear, I don't store my chargers plugged in. My point was more about when charging at the end of the day, don't worry about getting it unplugged at the end of the charge cycle in the middle of the night. The next day will be fine!How much effort is it to pull a plug out of a wall socket? I do that just because the manufacturer just might know a bit more about such things than I do and it is really no problem to simply walk over and pull the plug out.
Excellent point for most part that works fine but indeed unplugging it is the best policy and don't recommend leaving any charger connected for a excessive length of time unless it's specifically designed to maintain a battery at a certain level long term.To be clear, I don't store my chargers plugged in. My point was more about when charging at the end of the day, don't worry about getting it unplugged at the end of the charge cycle in the middle of the night. The next day will be fine!
your talking appliances that have on and off switches. the charger is aways powered on and and ready to pump out current into the battery. now days most appliances are never fully off either.This makes just about as much sense as unplugging a toaster when your toast pops up. Or for that matter unplugging your washing machine at the end of a wash cycle.
Not true.your talking appliances that have on and off switches. the charger is aways powered on and and ready to pump out current into the battery. now days most appliances are never fully off either.
