PaleBlueDot
thanks for the review! i got my stand in 2 days from Amazon. there on sale for 57.99$ https://www.amazon.com/gp/product/B00ZF2QV9C/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Just to throw out a thought. I have never worked on a bike in-depth so could someone tell me the big difference in working on a bike using a bike stand as opposed to working on it by turning it over and resting it on handlebar stands? I do realize that an in-depth bike service/assembly would require a bike stand, but wouldn't handlebar stands suffice for that simple adjustment or basic maintenance?
If you have the room on the ceiling in your garage, use this to lift the bike on your seat post stand.View attachment 63153
Thank you for posting. How compact is the stand when folded up?The YaheeTech workstand arrived from Amazon today. I was searching for a stand in my post above on Aug 13 that would support my XP as well as our other non electric bikes. I think that this one will work well for $80. It supports up to 66 lbs so I removed the battery just to make the XP easier to mount. I am able to support the entire bike to run through the gears and adjust the brakes. However I think that for wheel removal I will position the stand to allow the wheel that I am not working on to be supported by the ground to improve stability. Overall I think that the Yaheetech workstand is a well engineered and built product and i am pleased with my purchase. Photos are attached.View attachment 62843View attachment 62844View attachment 62845
Here is my Lectric XP Workbench. I designed it to enable me to work on the bike, without having to lift the bike up. The workbench is held together using only 4 wingnuts and 2 clevis pins.
I prefer to work on the bike upside down using the handle bar jacks. It makes for the most stable scenario if the back is supported on the back rack (and not the seat). It puts everything right up where you want it. You don't even need the handle bar jacks. Foam blocks from shipping boxes work great too. See pic...via Jeremiah McInTosh video.It is much easier to just turn the bike upside down, then trying to remove the wheel on the stand (at least for me). While it is possible to remove the wheel on the stand, I just turn it over by placing the bike on it's side (kick-stand side down), after placing Handlebar Jacks on. (https://electricbikereview.com/foru...ew-ultra-portable-bicycle-repair-stand.28180/). I place a towel, door mat, etc. next to the seat, then lift the bike up to rest on the Handlebar Jacks and the seat. I then lift the rear wheel using the rear rack and place a small 2 step stepladder under the rear rack. This raises the rear wheel up to a comfortable height. This method probably involves actually lifting no more than 30 pounds of unsupported bike weight.
