I am building a hunting fat bike.  20" x 4" wheels.  Don't care about weight.  I want it to be able to pull a trailer.  Total combined weight of 500 lbs.  Grades between 20 and 40 percent.  I would prefer to stay with a gearless, direct drive hub motor.  I am designing it with one motor in the back but may have to upgrade to one in the front as well for more traction, torque, and balance, but will try it with one motor to start with.  I don't care about how large the hub motor has to be to accomplish my goals.  I am starting my calculations with a small 5000 watt gearless hub motor, 960 winding, 190 nm, 72 volts 60 ah, Peake phase current 300 amp, and a 150 amp controller.  I will be running a hot rod cooling system.  I know this isn't enough information to get a very accurate calculation but I am just looking at an approximate one.  I would like to use zero rider power input into the system to start with.
Is this feasable, do I need more power or two motors, or is it impossible?
