I have been looking for a good rear rack solution for the full suspension Haibike. The Old Man Mountain rack looked like a good start but it had one critical flaw. The pucks that are designed to to secure the stabilizer brackets to the Haibike triangular swing arm are pretty close to being useless and if you can make them work they look ridiculous with the zip ties and poorly fitting puck.
i just couldn’t tolerate the pucks so I had to design and make my own. These brackets are 3D printed ABS plastic. I am planning a few more design changes but I think the work an look a lot better than the Pucks supplied with the OMM racks. Everything else about the rack seems to be top quality, but they really need to step up their game with the pucks. I think they tried to come up with a one size fits all solution but it just doesn’t work for the Haibike
the first photos are of the puck system. You can see how poorly they fit and I even had to put foam on the inside of the metal bracket so it wouldn’t rub on the frame.
the last photos are of my new bracket system. The bracket completely surrounds the frame and provides a flat surface to mate the bracket to. It also aligns the arm vertically with its attach location on the rack so that it doesn’t bend the arm.
I am working on refining it and it would look better with black hardware, but the stainless steel is probably a better material for the application.
