Recently a few people commented on the review of the Stealth Bomber I did asking how to get into competition mode (to make the bike go faster than 20mph) and initially I suggested just using the Cycle Analyst computer to switch modes. One person had just got their bike recently and lives in Canada and was unable to find an option like this with their bike.
I dug a little bit deeper and it sounds like some of the newer models are limited and require a physical change in order to unlock the higher speeds. This is what I found:
If anyone else could confirm this or add their experience and pictures to help others out that would be great. I'm curious how it works and would like to know more about the backstory on why they switched from allowing higher speeds just using the LCD computer and now have it hard wired in. Just like fancy cars, it's up to the rider to obey speed limits or take it to a track and let her fly. In the case of the Stealth ebikes, it's up to the rider to ride responsibly but maybe there was pressure on the company to make it harder for riders to go fast based on some legal situation or something?
Apparently newer models have a governed controller... When you look at the underside of the speed controller there is a red or black wire that comes out and then goes right back in. It's about the length of the controller and in order to unlock the higher speeds this connection needs to be broken. You can add an inline switch here to make it easy to go back and forth. This may void your warranty and is only an observation, not a recommendation.
