This does not make sense!?I have a quick release seat post clamp as part of my theft deterrence setup
My Ultimate Commuter has a quick release seat post, as well as pedals that have a quick release feature. When my ebike is secured with the ABUS Bordo, and lacks a seat and pedals it's a bit more of a deterrent than an ebike only secured with a lock. Granted, if my ebike has been singled out for thievery and a thief has made needed provisions then all bets are off. Let me know if you need more detail @webcurl.This does not make sense!?
OK, sorry, you take them off with the quick release, it all makes sense now. Yes, not a bad strategy at all, no seat, no pedals for quick get away, i like it. Not for me though, but respect!My Ultimate Commuter has a quick release seat post, as well as pedals that have a quick release feature. When my ebike is secured with the ABUS Bordo, and lacks a seat and pedals it's a bit more of a deterrent than an ebike only secured with a lock. Granted, if my ebike has been singled out for thievery and a thief has made needed provisions then all bets are off. Let me know if you need more detail @webcurl.
I've never heard of quick release pedals. Anyone got a link?
Something I have started to notice is that trouble I sometimes have shifting/indexing of the Rohloff happens more in cold weather (let’s say under ~31 F).
This is because the oil in the hub has different viscosity. You need to change the oil proportion if you are leaving your bike in very cold condition.
Here is what Rohloff recommends:
Read more here: https://www.rohloff.de/en/service/handbook/faqs
I am happy with the power, I have not tried it with 750 yet, but I imagine decreasing it will make hill climbing slower (currently with a lot of hard peddling I can maintain 22-25 on the biggest hills I tackle daily). My main concern is for the health of the Rohloff, I would be very very sad if it were to fail. I failed to account for the more catastrophic nature of IGH gear failure vs easy to replace chain/cassettes.
Because of the amount of power it puts out and the occasional weird mis-shifts I have been stressed about damage. The shifts have been getting better, whether due to wear in, more experience, belt tension or a combination I am not sure, but mis-shifts happen less often (for a while is was several times every ride) so I am less stressed. And I have just about completely eliminated gear slip/skip using gears 5-6 to start out as Pushkar advised. it will be interesting to see what the correct starting gear with a 60 tooth front socket will be, 4-5?
After every ride? How often do you have to adjust? And i can't see where you can get a tension gauge for $12?I don't guess when it comes to adjusting belt tension, I have two belt tensioning tools which are very inexpensive and I check the belt after every ride. I have never had a belt skip, jump, or break on any of my belt drive bikes and I've been riding them for ages. You also mentioned gears skipping/jumping, that shouldn't be happening I would have the hub looked at. I don't baby mine and do a wheelie when it's safe from most lights and of course when traversing logs or other obstacles off road or on trails. Nice review, thanks. One of the tensioning tools I use is an app I downloaded from Gates which enables you to use you're phone to set the tension. That's free and easy to use and the other tool I use is a little spring loaded device available from Gates or on eBay for about $12.
@webcurl, there are inexpensive tensioners available, but I've only used the Gates Carbon Belt drive android app and it's always worked for me: https://play.google.com/store/apps/details?id=com.gates.carbondrivecalculator&hl=en_US
Yup, that's the one that is included in all orders since Feb 2020.![]()
I've only ever used the app and yes it requires a quiet environment and practice "plucking".i check the tension after every ride I didn't say I adjusted it. Have you seen the various gauges? There's nothing to them, sorry if you paid more.
