Using a fast charger means shorter battery life ==> expenses in the future. Grin Satiator does not work with many batteries.
nope, it pretty much works with all ebike batteries or 24/36/48volts packs aether they are for a lawn mower or a scooter.
Fast is not 6-8amps unless  the battery amps are 10amps or lower. Like most packs are 11.6  or 12.6 amps, charging at 6.2amps is totally fine.
It cost xtra time, materials, design , etc to build a good fast charger , that's why the 2 and 4amps chargers are  common.  But Bosch nevertheless will sell that dumb charger for 200$+tax
Charging to 90% is much more important and you can control that with the Satiator .
  A pack can last 2-3000cycles charging to 80-90% and discharge  to 20%.
   It will last 5-600cycles if up to 100% constantly.
   Mine i set it up with Grin with 4 custom charging profiles.
   Can also connect it to the Mac and do all sorts of analytics.
    They sell different adapters for all types of charging plugs.  Rosenberg, anything...
Voltage is 24/36/48/52 and a separate one for 72v .
Any battery type- Lithium, nickel, etc...
   That's what i had to do on mine. I used my old 2amp charger plug and Solder it to the Grin cable and it  was good to go.
      Is like having a mini super portable  battery with you. As long as there is an outlet around. That can also be planned in advance of a big trip.
 A spare battery takes a LOT of space and is HEAVY.
