AHicks
 - USA
- City
 - Snow Bird - Summer S.E. Michigan, Winter Gulf Coast North Central Fl.
So much of this thread still seems to be more about controller differences and how different software used cadence and/or torque sensors together or separately to control the power applied to the motor. I only have two hub motors, one is Cadence only, the other is cadence and torque supposed to be so much better, but I find it only better at some things like smith starts if you're not use to an e-bike/cadence sensor and have no throttle. The problem with my Cadence/Torque hub motor (Juiced), is that I cannot get the power level I want for the cadence I want, not by adjusting gears or assist level. With my cadence only hub I can get it right as long as I have the right gear (so not very good at top speed due to limited/unsuitable gear ratio). On the Hub/torque bike often at many cadences, it does not matter what assist level I'm in for a given gear and cadence I get the same speed, to me, if I increase the assist I want faster speed without changing anything else. Now I don't have a mid-drive yet (probably buying one next, but more for the IGH than the motor. A lot of what I read in this thread I've experienced between my different implementations of Cadence and Cadence/torque implementations, so I still don't really understand what might be really different with a mid-drive. The saving grace on both my bikes is the throttle, as that is the only way I can control the assist properly for the given terrain, available gear ratio, cadence, and my desired energy output. I might be more affected by this as I have a relatively low cadence, and cannot do a high cadence for any length of time, but I can keep a low cadence very well even with a fair bit of power behind it. To me most bikes are not properly geared for this.
Maybe, if you were so inclined, you could consider a bike where you are able to change/modify PAS levels? Or, possibly better yet, modify your own bike with the installation of an aftermarket controller? Speaking from my own experience with an aftermarket controller, I think the ability to set up the controller using settings I like, vs. those the OEM's think (guess?) I should like, makes a night and day difference in the riding experience. That's me though...
