Mass Deduction
Batteries should not warm on 2C discharge. They're likely rated for 25C or more.
Yes, if it's discharged, plug it in and charge it up.
For near daily riders there's no need for any special care. Just charge and go. The trickle chargers supplied are as safe as you can possibly get, and will condition/balance your cells on each full charge. It's better to charge them all the way up if you're going to use the bike.
L-ion cells don't have a 'memory' effect, think...cell phone. Charge and go.
If you're typically charging to about 70% (and draining to 30-40%), wouldn't it take a very long time before any of the cells became so imbalanced that it started to create a problem? And that's assuming that the BMS on board the battery can't balance the cells on a cell-by-cell basis, which some of the better ones can (and I'm guessing Bosch and Shimano probably use some pretty good BMSs, but I'm more than happy to be educated to the contrary if Bosch and Shimano don't use BMSs as good as I think they may be).
From what I understand, Li-Ion cells do very slowly develop a very minor memory effect, but that it's so slow that most people fully discharge/recharge before it ever becomes noticeable.
That said, I will be fully charging the cells from time to time right before using the bike, and even fully draining them on rare occasions. So I think if I stay in that 25-75% zone most of the time, with very occasional full charge/full discharge, I'll be in good shape. I will definitely recharge promptly after any full discharge, and will typically wait until as close to the ride-time as reasonably possible before a full charge.
